10-29-2021 01:01 AM - edited 10-29-2021 01:02 AM
Hi Team ,
Can you please share your experience or advice on what information need to be provided to Management or client in Network Monthly reports .
we have Solarwinds , Nagios , HP servicenow tools from which we can pull the reports .
Please share your experiences here . What type information you provide and what is expected in that report . In which format you send that report to client . Any sample dashboard you can share ?
Thanks in Advance .
10-29-2021 02:15 AM
The tools mentioned all of them can do the job as you required.
its business to business changes, if the technical manangment they look deep technical report. if only business they look for availability of the report.
you can find many of them, but you need to be spefic what the management looking for :
example :
https://www.solarwinds.com/network-performance-monitor/use-cases/network-availability-monitoring
10-29-2021 02:38 AM
HI @balaji.bandi Thanks for your response ..Management looking for Network KPI report .
10-29-2021 08:32 AM
Guys, Please help me here ....
Help required on Network monthly KPI report ....
