Highlighted
Beginner
Hidden/Secret CLI Commands
Hi Everyone!
I'm using a Cisco WSA asyncos, a Cisco ESA ironport and Cisco SMA.
I'd like to know where I can find or know all of their secret cli commands.
For example I know the "ARP" command but the list of commands indicated in the user guide doesn't show up.
Please I'd really appreciate you guys can tell me that. That would help me a lot!
Best,
Karla
3 REPLIES 3
VIP Advisor
Re: Hidden/Secret CLI Commands
Generally what ever command required those alraedy in menu driven. hidden commands are used for Cisco TAC.
They are not all documented. like example :  ipcheck to check your raid controller working as expected...
BB
*** Rate All Helpful Responses ***
Beginner
Thanks for the quick reply balaji.bandi,
Basically what I am looking for are list, show or check commands and not configuration ones.
If you can show me more of them that would be owesome.
Most of the time, I need to run into test whether it be connectivity, third party configuration or health checking. Furthermore, when any incident appears i need to prove that they're not my appliances' fault.
All of them are just for testing purposes.
Best,
Karla
VIP Advisor
Not many commands hidden one we can use in day to day for checking, we use curl out of the box to test WSA working as expected.
here is the example  i use in Linux
curl https://www.bbc.co.uk  --proxy http://192.168.1.1:8080  ( this example IP i used for reference)
BB
Content for Community-Ad
July's Community Spotlight Awards
