I'm getting something that looks not normal to me, while I see the memory usage dropping I notice that the process Licensing Auto U (which I assume Auto Update or something) is consuming a big part of it.
Is this normal or something need to be corrected?
ASR1001-X# sh proc mem sorted allocated
Processor Pool Total: 3875368184 Used: 401770392 Free: 3473597792
lsmpi_io Pool Total: 6295128 Used: 6294296 Free: 832
PID TTY Allocated Freed Holding Getbufs Retbufs Process
63 0 2932834000 2932834000 29864 0 0 Licensing Auto U
0 0 940095016 611503200 309182568 0 0 *Init*
287 0 172206920 141776192 5128528 0 0 L2TP mgmt daemon
537 0 127582728 242523784 101864 0 0 SNMP ENGINE
116 0 114892480 58192 32296 0 0 IOSXE-RP Punt Se
536 0 114832224 0 101864 0 0 PDU DISPATCHER
0 0 92971928 88079848 1776552 17950279 0 *Dead*
298 0 71524752 97296064 2962136 0 0 L2TUN Applicatio
10 0 52587856 52628400 213512 50479182 50509102 Pool Manager
523 0 34700704 34700560 54008 0 0 mdns Timer Proce
524 0 33972352 51720 34296632 0 0 SBC main process
459 2 21113656 21058352 126200 0 0 Virtual Exec
184 0 19116584 10814464 2503152 0 0 SSM connection m
71 0 16030112 6374880 8229736 0 0 IOSD ipc task
185 0 15914912 12956016 2807688 0 0 SSS Manager
418 0 14225776 11399872 2598024 0 0 VTEMPLATE Backgr
535 0 13638448 13527896 55584 0 0 IP SNMP
Thank you.
