02-21-2013 06:25 AM
Hello, anyone know if it is possible to view cached CDP neighbor information in LMS 4.2.
In LMS 3.1 it is displayed in the Device Center summary section, but I cant find it in LMS 4.2 Device Center.
BR /Crille
Solved! Go to Solution.
02-21-2013 07:05 AM
Click the "View Topology" button on the top right while in Device Center. That will flip your view into a graphical display of the device and its CDP neighbors - sort of a light version of the full topology view with some extra features. In the topology view hovering over any of the devices will give you both the CDP neighbor information as well as some bits from fault management and some SNMP info.
02-21-2013 07:05 AM
02-21-2013 10:51 PM
Thank you, you know your stuff
Have a nice weekend!
02-22-2013 07:58 AM
You're welcome. Glad it helped. Thanks for the rating.
03-21-2013 11:59 PM
Interestingly, do you believe what CDP is telling you? Check out the 'CDP Prank tutorial' here: http://www.og150.com/tutorials.php
These little OG150s are awesome....
DJ
