Beginner
Hostnames in DFM
I have four devices that are loaded into DCR and DFM and they are known devices. But they show up in the DFM as IP address and not as HOSTNAMEs. I have check them in DNS and they are correct. I have tried to have CW do a rediscovery but nothing changes. I was wondering when does CiscoWorks check device against DNS? Do I need to do a Stop and Start of Ciscoworks for it to re check DNS and update the hostname in DFM. I also have a question how often should you do the DOS stop and Start of Ciscoworks. Should this be scheduled either weekly or monthly to make sure every thing is in sync up.
6 REPLIES 6
Hall of Fame Cisco Employee
Re: Hostnames in DFM
If you're sure that DNS is properly configured, and directly maps IP to hostname then hostname back to IP address, then remove the affected devices from DFM, and re-add them. They should be managed as hostnames. If they still show up as IP addresses, add entries to the server's local hosts file, then remove and re-add the devices.
Highlighted
Beginner
Joe,
When I go into DFM the devices are already known and CW will not let me delete them the only way to do that is to delete them from DCR and that does not make sense. I do not want to lose all information tied to those IP address and devices. I thought re-discovery would work or shut down CW and restart is the only thing that makes sense but I was trying to use that a last choice.
In order to be able to delete devices from DFM, you need to disable DCR auto-sync. Once you do this, the Delete button will become active.
Beginner
Joe,
are there any negative effects from turning off and then back on Auto-Sync in DFM.
Teddy Agee
No.
Beginner
That's the ticket. Thanks Joe!
Content for Community-Ad
