05-08-2019 04:35 AM
on the 3650 boxes that have 16.3.6 denali, how much space is needed? I have a few boxes that have about 460MB's free after the 16.3.8 bin file has been copied over which is 535MB's. I also don't see the new install from TFTP line used if I had to install there. I found the tftp install using the older software install language but not request platform software package
1621966848 bytes total (458137600 bytes free)
atlpf3650-L1#
Solved! Go to Solution.
05-08-2019 05:56 AM
05-08-2019 05:39 AM
05-08-2019 05:47 AM
05-08-2019 05:56 AM
05-08-2019 06:02 AM
05-08-2019 06:16 AM
06-25-2019 07:02 AM
here you go on minimum space requirement..
In-Place Package Expansion for Software Images | The software image installation process is now optimized:
The installation procedure you have to follow remains the same. See Upgrading the Switch Software |
06-25-2019 07:37 AM
Thanks, everything worked out perfectly and I didn't need to do any extra cleanup. 20MB's extra space used seems about right but I had thought there was more expansion from when I went to 3.x to denali but this was from denali code to denali code and everything worked out fine. thanks for getting back
