How See Live traffic by IPS in CLI Cisco
Hi dears in cisco routers or L3 swiches Have any tools in CLi that see live traffic ips by tx or rx of ips
Recoomand solution used netflow or sflow by flow collector
Some vendor like mikroitk have torch tools for do this in inteface or vlans
Have any suggest ?
the command:
show ip traffic interface <interface_name>
is probably the closest you get without using Netflow, SPAN, or any third party tools...
5 Replies 5
balaji.bandi
IPS means IP address ? or IPS (Intrusion Prevention System) ?
You can use tool to monitor session or span the port to look - some devices do support NBAR / NetFlow and Sflow you mentioned.
Its all device capabilities, Higher end product do support different features  in nexus to capture the traffic.
BB
Hi ip address means For standalone Switch How Can do this?
I Donnot have any Flow collecotor
For a few second I need on nexus L3 port ip addresses and TX RX traffic
what nexus model and what nexus code ? - check below guide to capture
https://www.cisco.com/c/en/us/support/docs/switches/nexus-7000-series-switches/116136-trouble-ethanalyzer-nexus7000-00.html
BB
Nexus does not support that command as per i know, that command is ok on Enterprise switches.
BB
the command:
