How to analyze every switch ports traffic of a Cisco Catalyst 3650G switch?
MauroTridici
Dear Users,
I'm a newbie and I'm trying to analyze the traffic on all the ports of a Cisco switch using Snort.
I know that I can use the port mirroring feature to copy the traffic running on source port to a destination port monitored by Snort. But, if I need to analyze all the switch ports, how can I do the work?
Can I consider the switch uplink port as source port? Or I should do it in a different way?
Thank you in advance,
Mauro
5 Replies 5
marce1000
 - You might use a 'span copy' of the uplink port ,check this document for more info's :
                 https://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-series-switches/10570-41.html
 M.
-- ' 'Good body every evening' ' this sentence was once spotted on a logo at the entrance of a Weight Watchers Club !
marce1000
 - FYI(2) : https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3650/software/release/16-6/configuration_guide/nmgmt/b_166_nmgmt_3650_cg/b_166_nmgmt_3650_cg_chapter_011.html
 M.
MauroTridici
Sorry for my late answer.
Thank you very much to all of you.
I really appreciated.
Mauro
No worries, Hope our information is very helpfull for you, if this was resolve mark as resolution, so other community member can use as reference - if they have same query.
BB
