10-18-2013 08:30 AM
Good Afternoon
I'm trying to implement some EEM scripting. My objective is to apply a QoS policy to an interface based on the availability of a track statement.
When the track is down i want to apply the QoS policy, when the track is up I want the policy removed from the interface.
interface has no QoS applies during normal operation
interface FastEthernet0/0
ip address 10.10.10.3 255.255.255.0
duplex auto
speed auto
I have created relevant, class-map, policy-map, and tack statement and event manager applet as per below.
Router ios is 7200 Software (C7200-SPSERVICESK9-M), Version 12.4(22)T,
########### Event Manager version is as follows :
R2#show event manager version
Embedded Event Manager Version 3.00
Component Versions:
eem: (v300_throttle)1.1.267
eem-gold: (v300_throttle)1.0.8
eem-call-home: (v300_throttle)2.0.0R2#show event manager version
Component Versions:
event manager applet POLICE
event track 2 state down
action 1.0 cli command "enable"
action 1.5 cli command "conf t"
action 2.0 cli command "int fa0/1"
action 2.5 cli command "service-policy input POLICE"
action 3.0 cli command "end
###### track statement learned via eigrp #####
track 2 ip route 2.2.2.2 255.255.255.255 reachability
##### shows track as being down and EEM applet being tied to the POLICE config
Track 2
IP route 2.2.2.2 255.255.255.255 reachability
Reachability is Down (no route)
4 changes, last change 00:19:11
First-hop interface is unknown
Tracked by:
EEM applet POLICE
Based on this information I would expect or hope that the event manager would kick in as the track statemnet is clearly down, however when i run the following command no output is returned
R2#show event manager policy active
"debug event manager all" returns nothing I can see that the policy is registered.
R2#show event manager policy registered
No. Class Type Event Type Trap Time Registered Name
1 applet user track Off Fri Oct 18 15:49:46 2013 POLICE track 2 state down
maxrun 20.000
action 2.0 cli command "int fa0/0"
action 3.0 cli command "end"
Is there an issue with my config? Is what I am trying to achieve possible (I assume it is)
Any help would be greatly appreciated
Solved! Go to Solution.
10-18-2013 05:51 PM
Well, the policy will run very quickly, so you may not catch it in policy active. Look at show event manager history events to see if it ran.
Config-wise it looks okay. If you have AAA command authorization configured, you will need to configure "event manager session cli username USER" where USER is a username authorized to run these CLI commands.
10-18-2013 05:51 PM
10-21-2013 05:43 AM
Thanks Joseph
I can see the following which is a good sign.
No. Job Id Proc Status Time of Event Event Type Name
1 1 Actv success Fri Oct18 15:35:56 2013 track applet: POLICE
2 2 Actv success Mon Oct21 13:17:28 2013 track applet: POLICE
On a final note will the policy be automatically removed once the track statement is up or do I have to right a reverse policy to remove the QoS on the interface as below
event manager applet REMOVE-POLICE
event track 2 state up
action 2.5 cli command "no service-policy input POLICE"
Cheers
10-21-2013 08:29 AM
That looks fine.
