07-08-2010 07:15 AM
Hi All,
How can we archieve configuration in ciscoworks for 4404 wireless controller.
Thanks in advance.
Samir
Solved! Go to Solution.
07-08-2010 04:36 PM
The WCS controllers are supported just like any other device. Make sure you have either telnet or SSH enabled for config archive transport, then before a Sync Archive on your controllers. RME will log into them, and run "show running-config" to extract the configuration.
07-08-2010 04:36 PM
07-09-2010 06:47 AM
Hi Joe,
Thank you very much for your reply.
Samir
