How to backup configuration of an ASA5540
udj
I'm currently backing up the configuration of my cisco switches to a TFTP-server via SNMP using ccCopyProtocol (CISCO-CONFIG-COPY-MIB).
Is there any way I can do the same with the ASA5540 firewalls I have?
The ASA5540 doesn't seem to support this MIB, as far as I can read.
Does anyone know if it is possible to have the firewall copy its configuration via SNMP?
Ulrik Jensen
Joe Clarke
This is not possible. You will have to script a telnet or SSH session to the device to pull the config via screen scraping, or via a CLI-driven copy operation.
Joe Clarke
You can use RANCID for this.
Thank you .. I just googled it, and it seems RANCID doesn't do Windows .. and unfortunately I don't do Unix ;-) Seems like an okay tool though.
Thank you .. I will take a look at it, and do a scriptet terminal session instead on the firewalls.. I just tested it, it's pretty simple .. the error handling is the tricky part when scripting this :)
I did like the SNMP-way though, but when it's not possible, I will have to do the scripted telnet with clear text passwords in my (DOS)script.
Thanks for the quick reply :)
/Ulrik
