03-09-2008 09:12 AM
How do you do it? What are the exact lines I need to input? I have researched this online and I think there is a way using CAR, but I just get more confused. here is my current config below. I appreciate any help.
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
no service dhcp
hostname xxxxx
enable secret xxx
enable password xxx
username admin password xxx
ip subnet-zero
ip domain name xxxxx
ip name-server x.x.x.x
ip dhcp excluded-address 10.10.10.1
ip dhcp pool CLIENT
import all
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
lease 0 2
ip dhcp pool xxxxx
ip audit notify log
ip audit po max-events 100
ip ssh source-interface Ethernet0
ip address-pool dhcp-pool
vpdn enable
vpdn-group pppoe
request-dialin
protocol pppoe
interface Ethernet0
ip address 10.10.10.1 255.255.255.0
ip nat inside
no cdp enable
hold-queue 32 in
hold-queue 100 out
interface Ethernet1
ip address dhcp
ip nat outside
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname xxxxxx
ppp chap password xxx
ppp pap sent-username xxxx password xxx
ip nat inside source list 101 interface Dialer1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
access-list 101 permit ip host 10.10.10.8 any
access-list 101 permit ip host 10.10.10.36 any
access-list 101 permit ip host 10.10.10.39 any
access-list 101 permit ip host 10.10.10.54 any
access-list 101 permit ip host 10.10.10.55 any
access-list 101 permit ip host 10.10.10.63 any
access-list 101 permit ip host 10.10.10.78 any
access-list 101 permit ip host 10.10.10.85 any
access-list 101 permit ip host 10.10.10.90 any
access-list 101 permit ip host 10.10.10.91 any
access-list 101 permit ip host 10.10.10.92 any
access-list 101 permit ip host 10.10.10.102 any
access-list 101 permit ip host 10.10.10.116 any
access-list 101 permit ip host 10.10.10.123 any
access-list 101 permit ip host 10.10.10.126 any
access-list 101 permit ip host 10.10.10.127 any
access-list 101 permit ip host 10.10.10.134 any
access-list 101 permit ip host 10.10.10.144 any
access-list 101 permit ip host 10.10.10.158 any
line con 0
exec-timeout 120 0
no modem enable
stopbits 1
line aux 0
stopbits 1
line vty 0 4
exec-timeout 120 0
login local
length 0
scheduler max-task-time 5000
end
03-14-2008 07:14 AM
go through this document Cisco 800 Series Routers Configure
http://www.cisco.com/en/US/products/hw/routers/ps380/tsd_products_support_configure.html
03-16-2008 04:36 AM
basically you need a class map, a policy map and an access-list matching your clients and apply that to your interface.
class-map match-any clients
description limited clients
match access-group 89
policy-map clients
class clients
shape average 512000
access-list 89 permit 10.x.x.x
M.
