How to capture packets on ASR9K and NCS5500 ?
sasiven
I see monitor capture cli is not available in ASR9k and NCS5500
how to login to line card and so that to do tcpdump
marce1000
 - For the ASR have a look here :
          https://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r6-1/interfaces/configuration/guide/b-interfaces-cg-asr9k-61x/b-interfaces-cg-asr9k-61x_chapter_01001.html#ID-1755-00000031
 M.
I check using the show command, but how to save it as pcap file ? how to view the packets ?
any idea about login to linecard and do tcpdump ?
RP/0/RSP0/CPU0:R2#show monitor-session counters
Mon May 25 16:10:11.067 PDT
Monitor-session cap1
HundredGigE0/1/0/0
Rx replicated: 3 packets, 384 octets
Tx replicated: 3 packets, 384 octets
Non-replicated: 0 packets, 0 octets
RP/0/RSP0/CPU0:R2#
how do you then export the packets?
