Highlighted
Beginner
How to check ping results
Hello ,
I need to create a EEM script that check a ping results .
If ping are working or not and then to continue the script by this result .
thanks !
event manager applet ping
event syslog pattern " %DIALER-6-UNBIND: Interface Vi2 unbound from profile Di0" period 1
action 1.0 cli command "enable"
action 2.0 cli command "config terminal"
action 3.0 cli command " interface dia0"
action 4.0 cli command "ppp pap sent-username ron@x password 1"
action 5.0 cli command "shutdown"
action 6.0 cli command "no shutdown"
action 7.0 cli command "event timer countdown time 30"
action 8.0 cli command "do ping 8.8.8.8"
end
2 REPLIES 2
Highlighted
Enthusiast
You may refer to the below syntax:
 event syslog pattern " %LINEPROTO-5-UPDOWN: Line protocol on Interface Loopback1, changed state to down" period 1
 action 2.0 cli command "conf t"
 action 3.0 cli command "do ping 8.8.8.8"
 action 4.0 regexp "100 percent" "$_cli_result"
 action 5.0 if $_regexp_result eq "1"
 action 5.1  syslog priority debugging msg "Ping success"
 action 5.2 end
 action 6.0 if $_regexp_result eq "0"
 action 6.1  syslog priority debugging msg "Ping fail"
 action 6.2 end
debug:
*Aug 8 13:28:35.715: %LINK-5-CHANGED: Interface Loopback1, changed state to administratively down
*Aug 8 13:28:36.723: %LINEPROTO-5-UPDOWN: Line protocol on Interface Loopback1, changed state to down
*Aug 8 13:28:36.723: %HA_EM-6-LOG: ping : DEBUG(cli_lib) : : CTL : cli_open called.
*Aug 8 13:28:36.723: %HA_EM-6-LOG: ping : DEBUG(cli_lib) : : OUT : IOU1>
*Aug 8 13:28:36.723: %HA_EM-6-LOG: ping : DEBUG(cli_lib) : : IN : IOU1>enable
*Aug 8 13:28:36.844: %HA_EM-6-LOG: ping : DEBUG(cli_lib) : : OUT : IOU1#
*Aug 8 13:28:36.844: %HA_EM-6-LOG: ping : DEBUG(cli_lib) : : IN : IOU1#conf t
*Aug 8 13:28:36.967: %HA_EM-6-LOG: ping : DEBUG(cli_lib) : : OUT : Enter configuration commands, one per line. End with CNTL/Z.
*Aug 8 13:28:36.967: %HA_EM-6-LOG: ping : DEBUG(cli_lib) : : OUT : IOU1(config)#
*Aug 8 13:28:36.967: %HA_EM-6-LOG: ping : DEBUG(cli_lib) : : IN : IOU1(config)#do ping 8.8.8.8
*Aug 8 13:28:37.090: %HA_EM-6-LOG: ping : DEBUG(cli_lib) : : OUT : Type escape sequence to abort.
IOU1(config-if)#%HA_EM-6-LOG: ping : DEBUG(cli_lib) : : OUT : Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
*Aug 8 13:28:37.090: %HA_EM-6-LOG: ping : DEBUG(cli_lib) : : OUT : !!!!!
*Aug 8 13:28:37.090: %HA_EM-6-LOG: ping : DEBUG(cli_lib) : : OUT : Success rate is 100 percent (5/5), round-trip min/avg/max = 5/5/5 ms
*Aug 8 13:28:37.090: %HA_EM-6-LOG: ping : DEBUG(cli_lib) : : OUT : IOU1(config)#
*Aug 8 13:28:37.090: %HA_EM-7-LOG: ping: Ping success
*Aug 8 13:28:37.090: %HA_EM-6-LOG: ping : DEBUG(cli_lib) : : CTL : cli_close called.
Highlighted
Beginner
Hey @ronsametcohen :)
@ngkin2010already posted a script showing exactly what do to, thanks!
The key info on this:
You can log custom Syslog messages with EEM, just like shown in the script by @ngkin2010 .
Then, just create another EEM Script that reacts on your custom Syslogs!
Let me know what you think and if you need help with that.
Best regards
Juls
Content for Community-Ad
