01-19-2021 12:07 AM
Hello.
I have Cisco Nexus 5596 running NX-OS 7.1(2)N1(1) that faced problem with hanged EEM jobs that occupied all available threads.
EEM applet is very simple:
event manager applet Schedule_Backup event timer cron cron-entry "0 1 * * *" action 1.0 cli command "backupconfig"
"backupconfig" is alias to command copy startup-config scp:/<...>.
Since last reboot of the switch (24 november 2018) all available EEM threads were occupied with hanged jobs so for now output of "sh event manager policy" looks like:
Key: p - Priority :L - Low, H - High, N - Normal, Z - Last s - Scheduling node :A - Active, S - Standby default class -5 applet events no. job id p s status time of event event type name 1 33 N A running Sun Dec30 01:00:00 2018 Timer Schedule_Backup 2 46 N A running Sat Jan12 01:00:00 2019 Timer Schedule_Backup 3 645 N A running Wed Sep09 01:00:00 2020 Timer Schedule_Backup 4 729 N A running Mon Nov30 01:00:00 2020 Timer Schedule_Backup 5 730 N A running Tue Dec01 01:00:00 2020 Timer Schedule_Backup
So applet stopped to run after December 01 2020.
event manager scheduler clear policy 33 and event manager scheduler clear all have no positive effect. All five jobs remain in status "running".
Can somebody advise how to clear scheduler threads without restarting whole switch?
01-19-2021 12:23 AM
as per the ouput they are not pending, they are scheduled to run.
you can view pendings :
show event manager policy pending
you want to clear 5
event manager scheduler clear policy 5
01-19-2021 12:46 AM
For now the output of "sh event manager policy pending" is:
Key: p - Priority :L - Low, H - High, N - Normal, Z - Last s - Scheduling node :A - Active, S - Standby default class -2 applet events no. job id p s status time of event event type name 1 784 N A pend Mon Jan18 12:00:00 2021 Timer Schedule_Backup2 maxrun = 20 2 785 N A pend Tue Jan19 01:00:00 2021 Timer Schedule_Backup maxrun = 20
I succeeded to clear both of it by executing event manager scheduler clear policy 784 and event manager scheduler clear policy 785
But i still have five active jobs listed in sh event manager policy pending that prevent the new jobs from executing:
If i execute event manager run Schedule_Backup i get this:
N5K01# sh event manager policy pending Key: p - Priority :L - Low, H - High, N - Normal, Z - Last s - Scheduling node :A - Active, S - Standby default class -1 applet events no. job id p s status time of event event type name 1 787 N A pend Tue Jan19 11:42:12 2021 Schedule_Backup maxrun = 20
The new job is added to pending jobs and will never be executed since five jobs are hanged in "active" state and can not be stopped.
01-19-2021 01:41 AM
since this is backup some where stuck, stop the event manager and clear the task and re-run.
also consider email success or failure of task - also make sure your track the task before run the same task again, if this was not completed.
01-19-2021 01:56 AM
Can you guide me how to stop event manager and then clear tasks?
In privileged exec mode "event manager ?" prompt results only this:
N5K01# event manager ? clear Clear event manager information run Trigger/run an event manager policy manually scheduler Embedded Event Manager scheduler
