How to clear/reset de campus manager databases ?
NicolasDemonty
Hi all,
Could someone tells me how I can clear de the CM databases ? More precisely, I would like to clear all the "best practice deviations" and "discrepancies" entries. Then I would like to launch a data collection again to repopulate the databases.
I would like to do that because if I fix some deviations manually (by correcting the problem directly on the switch without using the "fix" button of the campus manager discrepancies entry) then after the data collection, the databases are not refreshed and the entries still stay in the tables.
Best regards
Nicolas
Sven Hruza
Level 4
Level 4
did you try to use the "Acknowledge" button for the changes you did?
I think after that the entries should not come up once more.
Sven Hruza
Level 4
Level 4
yes but I would like that CM detects my modifications. I wouldn't like to check one by one which discrepancies I have to acknowledge because I have something like 400 hundred entries to check ...
After each full Data Collection, Campus should remove any discrepancy or best practice deviation regardless of whether or not it was fixed through Campus/RME.  If you are still seeing active discrepancies or BPD after a Data Collection, then either you are seeing a bug in Campus or on the device (i.e. in what it is reporting via SNMP).
However, if you do want to clear out the whole Campus database to see if that removes some discrepancies or BPDs which you have fixed, see my document at https://supportforums.cisco.com/docs/DOC-8796 .
