How to create a DNS SRV record on Cisco CNR 8.1.2.1?
Richard00
I am trying to create a SRV RR but I get "A general error has occurred". Few years ago, I was able to do it on another CNR but now I don't remember the right format to used.
  • On Name field = sip
  • TTL = default value of -1
  • Type = SRV
  • Data = I have tried with different options:
    • _sip._udp.myexample.com IN SRV 1 1 5060 asterisk.myexample.com
    • _sip._udp.myexample.com. IN SRV 1 1 5060 asterisk.myexample.com.
    • With/without "IN".
    • with/without "SRV"
But every time I get the error.
What value should I put on Data field to create a SRV RR?
Richard00
Actually, this is the correct way:
  • Name = _sip._udp.somename
  • TTL = a TTL value
  • Type = SRV
  • Data = 1 100 5060 asterisk.myexample.com. (Or whatever priority/weight/port/target value)
Jaime Valencia
This is the UC / Collaboration area, might want to move this to a relevant area.
java
if this helps, please rate
as far as I recall, this:
is definitely the correct syntax. The first '1' is the priority, the second '1' is the weight. Try:
_sip._udp.myexample.com. IN SRV 1 100 5060 asterisk.myexample.com.
or
_sip._udp.myexample.com. IN SRV 0 100 5060 asterisk.myexample.com.
Richard00
  • TTL = a TTL value
  • Type = SRV
