12-28-2013 04:46 AM
Hi ,
i have installed syslog server in my PC .
how can i enable all trapes in from routers and switches .
What commanda needs to be run in those devices .
Thanks in advance
TY
PS
12-28-2013 07:20 AM
To enable all the traps on cisco devices :
snmp-server enable traps
just to enable traps for syslogs:
snmp-server enable traps syslog
To enable syslogs logging:
logging
Thanks-
Afroz
[Do rate the useful post]
12-30-2013 12:48 AM
Hi Praveen
I agree with Afroj on the first two commands. For syslog logging use the follwoing commands. Ususlayy loopback interface is given as source interface.
logging host x.x.x.x
logging source-interface INTERFACE
You can also set the level of trap logging by using
logging trap <0-7>
http://www.ciscopress.com/articles/article.asp?p=426638&seqNum=3
Satrhvik K V
01-20-2014 12:45 PM
Hi Praveen,
Once you have the traps enabled, make sure you configure the host command
snmp-server host
Syed Khalid
