How to forward shadow directory to another Server PC
Fantaw Tesema
We want to forward the switches and routers configurations backup in LMS 3.2 to another machine.
How can I forward the shadow directory to TFTP server?
We think it is better to forward from LMS 3.2 than to fetch the configuration from the switches/routers to TFTP server.
Thanks in advance.
Tesema
5 Replies 5
yjdabear
You could simply export CWK's shadow directory and mount it on the TFTP server (or vice versa).
Thanks for the answer. Sorry but can you please enlighten me with more tips how I can do that.
Tesema
It depends on what OS your LMS and your TFTP server are running, respectively. Can you can post that info?
The TFTP server is Debian Sarge.
LMS 3.2 is installed on Windows server 2003 standard edition, service pack 2.
Thanks again.
Tesema
I will appreciate for any idea.
Tesema
