Cisco announces new innovations in SD-WAN, ISRs, SD-WAN Services, and Catalyst 9000 Series switches
108
Beginner
how to get logs for interface when my bandwidth cross 70% Cisco 3900 router
is there any way that I can get a log for the interface when my bandwidth cross 70% in my Cisco 3900 router
Highlighted
Re: how to get logs for interface when my bandwidth cross 70% Cisco 3900 router
Using an SNMP to poll the interface bandwidth statistics. And when a threshold is met you get alerted. Using something like solarwinds for monitoring would be effective.
Unless you have another requirement? Seeing top talkers IP/protocols you can look at netflow configuration.
Hi Sijo,
You can also you prime infrastructure to monitor interface parameters and set thresholds.
you can use below link for more details: https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-4/user/guide/bk_CiscoPrimeInfrastructure_3_4_0_UserGuide/bk_CiscoPrimeInfrastructure_3_4_0_UserGuide_chapter_01110.html
Content for Community-Ad
Blog-Cisco Community Designated VIP Class of 2019
