11-08-2018 10:11 PM
is there any way that I can get a log for the interface when my bandwidth cross 70% in my Cisco 3900 router
Solved! Go to Solution.
11-12-2018 06:41 AM
11-08-2018 11:29 PM
Using an SNMP to poll the interface bandwidth statistics. And when a threshold is met you get alerted. Using something like solarwinds for monitoring would be effective.
Unless you have another requirement? Seeing top talkers IP/protocols you can look at netflow configuration.
11-12-2018 06:41 AM
