09-26-2005 12:52 AM
I have a task to install cisco works 2000 on Windows 2000 Pro. I wander how to install cisco works 2000. What I should be prepared to. I think I need some files about it, Who can give me that? Thank you!
09-26-2005 01:42 AM
You can view all the documentation through the following link:
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/index.htm
For specific installation information, see this one also:
You will need to install Common Services first as this runs the web server and administrates the application. You can then install the other modules from there
Hope this helps
Kind regards
Marcus
09-29-2005 01:41 AM
Thank you for your reply, It's useful to me, but I still cannot solve my problem.
09-29-2005 02:52 AM
What are the details of the problem ?
