978
Highlighted
How to mornitor VSS (Virtual Switching System) & Stack (Switch) By Cisco Prime Infrastructure
Dear all,
I have 02 C6504-E with VSS (Virtual Switching System)
   and 02 C3750X-24T-L used Stack
How to you Cisco Prime Infrastructure to monitor VSS & Stack tatus?
Thanks.
5 REPLIES 5
Highlighted
Noone?
Highlighted
Up
Highlighted
It doesn't do this.
Highlighted
Thank you.
Could PI 2.0 do it.
And do you know any Cisco previous products can do it?
Highlighted
Participant
Virtual Switching technology is  the process of combining two standalone distribution switches found in  the local distribution layer into a single management point.
The Virtual  Switching System functions and appears as a single switch to the wiring  closet and the core layer. You can also create Virtual Switching Systems  with a pair of standalone switches available in the core layer.
For configuration please check  the below link:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.1/user/guide/configuration/configvss.html#wp1042960
Content for Community-Ad
