06-21-2011 03:56 AM
In campus database are discrepancy that have more than one year and which are already outdated. Configuration on Cisco devices has been corrected, but discrepancy are shown in "Campus Manager Discrepancy Report".
How to remove outdated discrepancy? (manually checking 500 discrepancy with logging on to the device and analyzing the configuration is not good solution)
The only solution to remove outdated discrepances what comes to my head is Campus database re-initialization.
But this is not an optimal solution because campus database re-initialization will clear Toplogy Services network map. Is it to possible to remove only discrepances from database ?
06-22-2011 04:38 PM
How often are you running data collection? The discrepancy gets updated after each data collection and UT acquisition cycle and should either increase or decrease. These are just recommendations of best practice and don't impact the functionality of your network.
To acknowledge the discrepancy, you will need to check the box at the top next to "Type" that selects all the "Unacknowledged" deviations and then click "Acknowledge".
06-27-2011 03:41 AM
Hello Mohammad,
Campus Data Collection is running every 4 hours and it works correct.
Campus Manager finds new discrepances at the end of each data
collection schedule, but not delete outdated discrepancy.
When the configuration on Cisco devices has been corrected,
Campus Manger do not remove outdated discrepancy from database.
I know that I can manually acknowledge the discrepancy, but manually
solution.
Thanks and best regards
Grzegorz
06-28-2011 04:51 PM
07-04-2011 07:52 AM
Hello Mohammad
I know that I can manually acknowledge Best Practice Deviation,
but this is not the answer to my question.
I would like to lms automatically update information about discrepances and netowrk deviation.
Manual removal outdated information in big network is not a good solution.
07-06-2011 01:25 AM
Hello
Mayby I formulate question a little differently:
How to delete all discrepances from database, without reinitializing the database ?
Next I will run campus data collection and discrepancy will be updated.
Regads
07-13-2011 04:48 PM
There is not an automatic acknowledgement method, only manual for now. And as you stated, running data collection will update the best practice deviation.
