06-26-2020 04:52 AM
Hi ,
Every time I do tftpdnld on ROMMON mode. why it always delete all my flash files? is there anyway for me to just copy bin file to the flash without having flash directory deleted, as there is some files that I want to keep there.
06-26-2020 05:04 AM
01-19-2021 09:04 AM
Cisco Router C881-K9
01-19-2021 09:38 AM
we need more information, what configuration you deleted.
can you post
#dir
# show run
what are you trying to achive, reset the device to factory default ?
01-19-2021 02:49 PM
If the router is in ROMMON, post the complete output to the following command:
dir flash:
01-19-2021 10:41 PM
Hi All,
So actually there were two discussions that I post. it was merged to this one post.
Ok the first problem. was solved
I have Cisco that goes to the Rommon because of Image bin file issue, whenever I do tftpdnld (copying bin files from my computer to flash: ),the flash directory was cleaned up first. I don't want that happens. so After searching again from internet. I found that I can boot from usb, with command: boot usbflash0:c881imagefilename.bin
after I can boot normally, then I could just copy bin file from Usb to flash as usual.
so my first discussion was cleared.
01-19-2021 10:57 PM
The switch could wind up in ROMmon mode due to these reasons:
