Can we retrieve the pre-shared keys from the configuration archive of ASA from Cisworks LMS 2.6 or higher version ? If so what the steps we need to follow the same.
What i understood is that you want to retrieve the pre-shared keys to deploy them on the devices. This can be done if you have the configuration backed by CiscoWorks and you can use the fuction - Configuration Quick deploy option to get it deploy on the devices.
