09-20-2019 05:45 AM
We're working on a 800 switch environment with Prime.
Is there any way to see 802.1.x. configuration on a group of switches?
Thanks in advance
09-20-2019 06:19 AM
You can get the aaa configuration from devices - it will give you 802.1x config.
We do from out of the box with shell script to get that information, or use Cattools from solarwinds to get that information.
Not sure with Prime this can be possible,
09-20-2019 09:35 AM
depending on how you've deployed prime, you can use the compliance tool. Now, your question was is there any way to see the config. the compliance tool doesn't really do that, but you can set up a template that includes the baseline of how the switches should be set up, and will show any discrepancies when you run the template.
other than that, I don't think there's a way to automate this. I mean you could always view the config archive in prime, but you'd need forever and a day to audit a large number of switches.
chris
