How to see Bundle Traffic or usages
aguntukkk
i have done 10+10=20 gbps bundle
how to see current usages on ether-channel
is there any command to see
interface Port-channel1
no ip address
no ip redirects
no ip unreachables
interface TenGigabitEthernet4/7
description Port-channel1
no ip address
no ip redirects
no ip unreachables
load-interval 30
no cdp enable
channel-protocol lacp
channel-group 1 mode active
interface TenGigabitEthernet4/8
no ip address
no ip redirects
no ip unreachables
load-interval 30
no cdp enable
How to see usage or current traffic on ether chanel through command mode ?
useing 7600 series router ?
I want to see live traffic
balaji.bandi
You can view below command :
show interface port-channel 1  <- this will show you 20GB in the output and usage
show interface port-channel 1 human (this will show you human-readable depends on IOS).
BB
i am getting like this after putting the bellow command
sh interface Port-channel 1
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 1w6d
Input queue: 0/75/31905/31905 (size/max/drops/flushes); Total output
drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 17112510000 bits/sec, 2061279 packets/sec
5 minute output rate 3404539000 bits/sec, 1369827 packets/sec
L2 Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
L3 in Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes mcast
L3 out Switched: ucast: 0 pkt, 0 bytes mcast: 0 pkt, 0 bytes
1698525090631 packets input, 1706754566329303 bytes, 0 no buffer
i want to know traffic usages of sub interface of port-channel 1
Example:
sh interface Port-channel1.809
Port-channel1.809 is up, line protocol is up (connected)
Hardware is EtherChannel, address is 442b.03d7.2e00 (bia 442b.03d7.2e00)
Description: Summit-internet
Internet address is 10.56.78.10/30
MTU 1500 bytes, BW 20000000 Kbit/sec, DLY 10 usec,
reliability 255/255, txload 44/255, rxload 218/255
Encapsulation 802.1Q Virtual LAN, Vlan ID 809.
Keepalive set (10 sec)
1706155970998 packets input, 1698149313032370 bytes
1120982354916 packets output, 338106432748371 bytes
L2 Switched: ucast: 39156631 pkt, 3552660869 bytes - mcast: 6291 pkt,
767246 bytes
L3 in Switched: ucast: 1705993321791 pkt, 1698137138669658 bytes - mcast:
L3 out Switched: ucast: 1120842549144 pkt, 338095512247801 bytes mcast: 0
pkt, 0 bytes
you see this here :
BB
