03-12-2008 02:40 AM
dear all,
I'm trying to know how can we configure ACS 3.3 to send all the logs/traps to NetCool server NMS.
is there anyway to do it ?
please advice
03-12-2008 06:03 AM
Upgrade to ACS v4.X remote logging to a non-ACS server first appears in this release train, V3.X and previous versions are restricted to only ACS servers remote logging.
If you cant upgrade then you will have to transfer the logs using the server Operating System.
03-12-2008 07:10 AM
thx for reply...
Currently i dont have the option to upgrade to 4.x, what do you mean by transfering the log using windows operation system ?
because as far as i know we can configure snmp service on the server and that can send traps to NetCool server but it will be normal windows traps , is it ?
Thnx and appreciate your help ...
03-12-2008 07:38 AM
Then google "Kiwi Logger" for a free tool that can do this for you.
