How to send special characters using EEM
pingduck
Is there a way to send Ctrl character using EEM's cli command action? e.g. ^C, ^^x
pingduck
Answering my own question. I found that I can enter "Ctrl-V" and then followed by the special character and it will work. The config also survives a reload. It is not as good as using escape characters like '\003' but nonetheless a serviceable solution.
balaji.bandi
Can you post the use case here for that special characters required in the script. so suggestion can be made based on the usage is possible or not, or any limitations.
BB
pingduck
Thank you for your feedback and solution, if it solve close the case as helpfull for other.
BB
