06-16-2021 02:00 PM
We currently using telnet to log into the network devices in Cisco Prime. SSH is not enabled. I have been assigned the task to enable ssh and disable telnet. I have created a CLI template to take care of enabline ssh version 2, creating a local user, and disabling telnet by using the 'transport input ssh' command. The issue i have run into in my tests are the credentials in the network devices. When select and click edit from a device in Inventory/Device Management/Network Devices, it still says that it is under telnet(see attached photo). Is there a way to update prime to change from telnet to ssh credentials? Rather, is there a way to do this in Bulk? Thank you in advanced
Solved! Go to Solution.
06-17-2021 12:10 AM
M.
06-17-2021 12:10 AM
M.
