Howto debug Prime Infrastructure performance issues?
Tobias Heisele
Level 3
Level 3
since the installation of the last patch (3.1.5 Update 2) the Prime is "slow" - at least the Gui is not really responsive. Sometime it is better, sometime it seems to be frozen. I tested different client, different browsers, disabled the proxy.
Does anyone know, how to debug such a behaviour? Which log file is to check? All vital parameters (CPU, MEM, Disk, IO & NIC) are ok, besides management of the devices is working fine.
Has been an issue with the alarm indexes within the oracle database - fixed by TAC
5 Replies 5
Mark Elsen
 - Depends . what platform are you using ; if VM; check your 'vmware tool statistics' to check mem/cpu/diskio (e.g.)
M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Thanks for your post, but in my case the vital parameter from the vm itself are all fine. That's why I'm looking for a possibility to debug inside the application. I'm missing the good old "pdshow" :-(
  - Did you size the prime-vm according to your network-size; as you might know during the installation you can choose  between a number of 'modes' of the VM  depending on how big the network is; did you do this correctly  ?
M.
       Beauty and terror
      Just keep going
       No feeling is final
it is a "Professional" installation (to enable the compliance engine) and in the System Management Dashboard all resources look fine, too.
