HTTP 404 Error after LMS 4.0 installation
schoerlin
Hallo,
I did make a fresh installation of LMS 4.0 on a Windows 2008 R2 (SAP1) server. During the installation I had no error message.
After installation I wanted to log in to the LMS Console with the "admin" user. The login was successfull but after zhis, I got an 404 error:
(see attached file)
Funnily enough it works with the "guest" user
Does anyone have an idea??
Thanks in advance
Frank
Error:The requested URL cannot be reached because ....
schoerlin
The problem is solved. It seems that something not was installed completely. I reinstalled the LMS and now it works.
