I am not able to Ping host host in OSPF Area 1 from OSPF Area 0
I have set up a simple OSPF network in Packet Tracer. I see all neighbors up - I am able to ping interface withing a OSPF area. I am unable to ping a host crossing over OSPF area.
I am refreshing myself on routing after a 6 year absence - Please be nice with your responses - What am I missing here?
PC - IP Address: 192.0.2.2  255.255.255.0
        Gateway :  192.0.2.1 255.255.250.
SW1
interface FastEthernet0/1   (Strait through to R1)
interface FastEthernet0/2  (Cross-Over to PC)
switchport mode access
R1
interface GigabitEthernet0/0/0     (Straight Through to R2)
ip address 10.1.1.1 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/0/1
ip address 192.0.2.1 255.255.255.0
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
router ospf 1
log-adjacency-changes
network 192.0.2.0 0.0.0.255 area 1
network 10.1.1.0 0.0.0.255 area 1
R2
interface GigabitEthernet0/0/0  (Straight Through to R1)
ip address 10.1.1.2 255.255.255.0
ip ospf 1 area 1
duplex auto
speed auto
interface GigabitEthernet0/0/1  (Straight Through to R3)
ip address 172.16.1.1 255.255.255.0
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
router ospf 1
network 172.16.1.0 0.0.0.255 area 0
R3
ip address 172.16.1.2 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/0/1     (Straight Through to SW1)
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
router ospf 1
network 0.0.0.0 255.255.255.255 area 0
SW2# sh cdp nei de
Device ID: R3
Entry address(es):
IP address : 192.168.1.1
Platform: cisco ISR4300, Capabilities: Router
Interface: FastEthernet0/1, Port ID (outgoing port): GigabitEthernet0/0/1
Holdtime: 171
SW2# sh int f0/1
FastEthernet0/1 is up, line protocol is up (connected)
R1#sh ip ospf ne
Neighbor ID Pri State Dead Time Address Interface
172.16.1.1 1 FULL/BDR 00:00:39 10.1.1.2 GigabitEthernet0/0/0
R1#sh ip int bri
GigabitEthernet0/0/0 10.1.1.1 YES manual up up
GigabitEthernet0/0/1 192.0.2.1 YES manual up
R1#ping 192.0.2.1
Sending 5, 100-byte ICMP Echos to 192.0.2.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 0/1/4 ms
R2#sh ip ospf nei
192.0.2.1 1 FULL/DR 00:00:35 10.1.1.1 GigabitEthernet0/0/0
192.168.1.1 1 FULL/BDR 00:00:34 172.16.1.2 GigabitEthernet0/0/1
R2#sh ip int bri
GigabitEthernet0/0/0 10.1.1.2 YES manual up up
GigabitEthernet0/0/1 172.16.1.1 YES manual up
R2#ping 192.0.2.2
Sending 5, 100-byte ICMP Echos to 192.0.2.2, timeout is 2 seconds:
R3#sh ip ospf neighbor
172.16.1.1 1 FULL/DR 00:00:39 172.16.1.1 GigabitEthernet0/0/0
R3#sh ip int br
GigabitEthernet0/0/0 172.16.1.2 YES manual up up
GigabitEthernet0/0/1 192.168.1.1 YES manual up up
R3#ping 192.0.2.2
Success rate is 0 percent (0/5)
R3#ping 192.0.2.1
R3#ping 10.1.1.1
Sending 5, 100-byte ICMP Echos to 10.1.1.1, timeout is 2 seconds:.....
R3#ping 172.16.1.1
Sending 5, 100-byte ICMP Echos to 172.16.1.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 0/0/2 ms
C:\>ping 192.0.2.1
Pinging 192.0.2.1 with 32 bytes of data:
Reply from 192.0.2.1: bytes=32 time=1ms TTL=255
Ping statistics for 192.0.2.1:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 1ms, Average = 0ms
C:\>ping 10.1.1.1
Pinging 10.1.1.1 with 32 bytes of data:
Reply from 10.1.1.1: bytes=32 time=1ms TTL=255
Ping statistics for 10.1.1.1:
C:\>ping 10.1.1.2
Pinging 10.1.1.2 with 32 bytes of data:
Reply from 10.1.1.2: bytes=32 time=1ms TTL=254
Ping statistics for 10.1.1.2:
C:\>ping 176.16.1.1
Pinging 176.16.1.1 with 32 bytes of data:
Reply from 192.0.2.1: Destination host unreachable
Issue resolved - Clear on its own
We are happy that you got to resolve your issue. As this is a Community so make a habit to share resolution also.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
