05-05-2022 10:00 AM - edited 05-05-2022 10:36 AM
Below is a lab topology where I've define OSPF on all except R2 router, top right edge. Everything has connectivity except to R2.
I want to have D1 and D2 ping R2 by using a default route. I will post the configurations, For switches: ip routing is turned on, D1 D2 interfaces are defined 'no switchport'
and A1 has a default gateway to R1
ip default-gateway 10.10.0.1
When I run a traceroute from the D1 and D2 Switches they arrive at R1 and get dropped
Can someone help me define a statric route on R1 to forward traffic to R2
Here is addressing table, with configurations to follow
R1 f0/0 10.10.0.1
f1/0 192.168.55.1
R2 f0/0 192.168.5.2
A1 Int Vlan 1: 10.10.0.4
D1 G0/1 10.10.0.3
no switchport
D2 g0/2 10.10.0.2
no switchport
R1 Router Config
hostname R1
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
clock timezone EXT -5
ip source-route
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
no ipv6 cef
archive
log config
hidekeys
ip tcp synwait-time 5
interface FastEthernet0/0
ip address 10.10.0.1 255.255.255.0
duplex half
interface FastEthernet1/0
ip address 192.168.55.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet1/1
no ip address
shutdown
duplex auto
speed auto
router ospf 123
log-adjacency-changes
network 10.10.0.0 0.0.0.255 area 0
network 192.168.55.0 0.0.0.255 area 0
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.55.2
no ip http server
no ip http secure-server
no cdp log mismatch duplex
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
ntp server 10.10.0.1 key 12556
end
A1 Switch Config
urrent configuration : 3184 bytes
! Last configuration change at 11:46:13 EST Thu May 5 2022
version 15.2
service compress-config
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone EST -5 0
ip cef
no ipv6 cef
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
interface GigabitEthernet0/0
media-type rj45
negotiation auto
interface GigabitEthernet0/1
media-type rj45
negotiation auto
interface GigabitEthernet0/2
media-type rj45
negotiation auto
interface GigabitEthernet0/3
media-type rj45
negotiation auto
interface GigabitEthernet1/0
media-type rj45
negotiation auto
interface GigabitEthernet1/1
media-type rj45
negotiation auto
interface GigabitEthernet1/2
media-type rj45
negotiation auto
interface Vlan1
ip address 10.10.0.4 255.255.255.0
ntp broadcast
router ospf 123
no ip http server
ip route 192.168.55.0 255.255.255.0 10.10.0.1
control-plane
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
D1 Switch Config
Current configuration : 3184 bytes
version 15.2
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
interface Vlan1
ntp broadcast
router ospf 123
no ip http server
control-plane
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
My Switch D2 configuration uses
ip route 0.0.0.0 0.0.0.0 10.10.0.1 in place of the D1 ip route, and has same results of connectivity up until 192.168.55.1 f1/0 of router R1 and cannot reach Router R2
So I am assuming a static route in R1 is what is needed for me to direct traffic to R2
Basic static routing is not something I've active practiced and I would like help with thsi
Any suggestions?
Solved! Go to Solution.
05-05-2022 10:52 AM
R1 have
static route toward R2
R1 is ASBR and redistribute this static route into OSPF
this make ALL router in OSPF know how reach R2
in R2
config default route toward R1
05-05-2022 10:07 AM
No topology attach ?
05-05-2022 10:22 AM - edited 05-05-2022 10:22 AM
Yes @MHM Cisco World stated a topology diagram would be good.
Another thing to note:
Understanding terminology will also help you when it comes to configuring routes out for getting to network devices.
A Default route states if you don't know where to send it, use the default route I have configured. It is usually configured like 0.0.0.0 0.0.0.0 <exit interface/next hop IP>
A static route a manually configured route that points you in the right direction to get to a specific route. A static route can be a default route but doesn't always have to be.
Without seeing a diagram what I would suggest is on every router that needs to reach R2 a static route of 192.168.55.0 255.255.255.0 <next hop of neighbor router>
Doing this with the next hop of each router of the link pointing to R2 (a diagram could help explain this better)
On R2 is where you would need the default route of 0.0.0.0 0.0.0.0 <R2s next hop into the network>
Hope that helps
-David
05-05-2022 12:20 PM
I hadn't even thought of this
I may try it now and see what happens.
Thank you for the help.
05-05-2022 10:47 AM - edited 05-05-2022 10:47 AM
as per the cnfig every router running OSPF, they learn the routes from each other
Make sure ip routing enabled - Make sure R2 have static route towards R1
ip route 0.0.0.0 0.0.0.0 192.168.55.1
post below output from all devices :
show ip route
show IP interface brief
show ip ospf neigh
from R2 are you able to ping - 192.168.55.1
can you post R2 config also.
05-05-2022 12:06 PM - edited 05-05-2022 12:15 PM
I am able to ping R1 from R2
I've enable IP routing on all switches
here is the topology
I can ping to f1/0 interface of R1 from A1, and not to f0/0 interface of R2
A1
Switch(config)#do ping 192.168.55.1
Sending 5, 100-byte ICMP Echos to 192.168.55.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 3/6/8 ms
Switch(config)#do ping 192.168.55.2
Sending 5, 100-byte ICMP Echos to 192.168.55.2, timeout is 2 seconds:
Success rate is 0 percent (0/5)
I want to accomplish this without OSPF and by defining default/static routes
The traceroute from A1 reaches 10.10.0.1 as it is the default gateway and gets dropped
*May 5 18:57:16.825: %SYS-5-CONFIG_I: Configured from console by console
Switch#traceroute 192.168.55.2
Tracing the route to 192.168.55.2
VRF info: (vrf in name/id, vrf out name/id)
1 10.10.0.1 16 msec 5 msec 5 msec
2 * * *
3 * * *
here is A1 Running Config
Switch#show running-config
Building configuration...
Current configuration : 3216 bytes
! Last configuration change at 13:57:16 EST Thu May 5 2022
version 15.2
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
interface Vlan1
ntp broadcast
router ospf 123
no ip http server
control-plane
I believe I need a route defined on R1 and I don't know how to do that to get traffic to go to R2
here is R1's configuration
with:
R1#show running-config
Current configuration : 1289 bytes
upgrade fpd auto
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
archive
log config
hidekeys
duplex half
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
router ospf 123
no ip http server
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
here is R1 routing table
Switch A1 Routing Table
And Configuration for R2
And Configuration of R2 Router
2#sh running-conf
Current configuration : 1103 bytes
upgrade fpd auto
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
archive
log config
hidekeys
ip address 192.168.55.2 255.255.255.0
duplex half
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
ip default-gateway 192.168.55.1
no ip http server
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
I just recognized R1 configuration includes :
gatekeeper
shutdown
05-05-2022 10:52 AM
R1 have
in R2
05-05-2022 12:18 PM
in R2
Thank you this worked perfectly. I will try redistributing into OSPF and removing this route to see if it has same results.
05-05-2022 01:23 PM
""for ICMP echo""
R1 have
""for ICMP echo reply""
in R2
05-05-2022 11:27 AM
If you HAVE to use static routes try the following:
It looks like you only need a static route on R2 to "get out to the network"
R2: ip route 0.0.0.0 0.0.0.0 192.168.55.1
everything else is connected to the 10.10.0.0 network
-David
05-05-2022 12:23 PM - edited 05-05-2022 12:24 PM
I have one last question
Would someone explain to me how having a default route defined from R2 to R1 helped map traffic from R1 to R2
I mean doesn't R1 already know how to get to R2?
I am missing the logic here of how this works.
05-05-2022 12:31 PM
R1 knows how to reach to R2, But R2 do not have any visibility of routes
remove that static route towards R1 and check show IP route
05-05-2022 12:49 PM
But I still don't understand how a route from R2 to R1 makes it possible to reach from R1 to R2 if R1 already has a route. Actually as I'm typing this maybe something to do with echo-reply?
05-05-2022 01:12 PM
This depends on the interface you are pinging. Plus you OSPF enabled for the 192.168.55.0 route and routes a dynamically learned. R2 doesn’t have this capability. So if you try to ping R2 you know how to get there but R2 has no idea how to get back. So I’m this case a default route configured on R2 saying go to R1 if you don’t know how to get somewhere and let him take care of it since he knows the routes.
