i want to use RTTMON MIBS for ICMP Latency
yucelbasoglu
Beginner
Beginner
I am using The Cisco 2811 Routers for Branch Officies and that use "ip sla" and EEM configuration for monitoring.
I find OID match Name and Stirng list.
is The following configuration true?
What can I use digit instead of rttMonLatestJitterOperOWMaxSD?
ip sla monitor 111
type echo protocol ipIcmpEcho x.x.x.x source-ipaddr y.y.y.y
request-data-size 1500
frequency 30
ip sla monitor schedule 111 life forever start-time now
event manager applet blabla
event snmp oid rttMonLatestJitterOperOWMaxSD.111 get-type exact entry-op eq entry-val 1 exit-op eq exit-val 2 poll-interval 5
action 1.0 syslog priority critical msg "BlaBla"
action 1.1 snmp-trap strdata "EEM detected BlaBla Latency"
Joe Clarke
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
You will need to use a jitter operation to be able to use this object.  Right now you're just doing an ICMP echo.  For that, you could monitor rttMonLatestRttOperSense (1.3.6.1.4.1.9.9.42.1.2.10.1.2.111).  If the value is something other than 1, then an error occurred (e.g. the round-trip response time was over the threshold, a timeout occurred, etc.).
Recognize Your Peers
