Hi all,
the customer has a following problem. He cleared a counter for the interface FE and from this time the snmp counter for iIfInDiscarrds remains same:-( See the output:
NIX4-C1# sh int et 4/2
Ethernet4/2 is up
Hardware: 10000 Ethernet, address: d0d0.fdb8.8475 (bia d0d0.fdb8.8475)
Description: NIX4-acc1 (850nm) #4
0 input with dribble 82 input discard
#snmpwalk from a server
iso.3.6.1.2.1.2.2.1.13.437784576 = Counter32:
82
It is before clearing counters. Than the customer cleared interface and after some time the output is following:
Ethernet4/2 is up
0 input with dribble 287072 input discard
82 - so there is no increment value (in this case - 287154)
The problem is on the Nexus 7000 C7010, NXOS - version 6.1(2) and ports are on the card N7K-F132XP-15.
Thank you
Bestr Regards
Roman
PS. Maybe this problem is linked with the change of the congestion-control algorithm from trust optimized to mesh optimized.
