Implementing voice router redundancy with two ISR 3400 routers.
sithum
The existing voice network is currently running on the Cisco 2900 router, and my intention is to replace it with a Cisco 4300 router. I'm looking to establish redundancy within the voice network using the new router, and I'm considering using HSRP. Can you confirm if HSRP is compatible with a voice network setup?
0 Replies 0
