In LMS 3.1, devices deleted in RME not removed from DCR
pblanc
Under LMS 3.1, I noticed that devices I delete in RME via the Pre-Deployed Devices screen or the Alias Devices screen come back after the daemon manager is stopped and restarted. Is this the intended behavior? If I remove one of these devices via the Device Management screen it does not reappear.
5 Replies 5
Joe Clarke
Yes, this is expected. Removing devices from RME does not remove them from DCR. If you want to get rid of a device completely, explicitly remove it from DCR.
Thank you for the info. Under LMS 2.6, when I deleted from RME, it was gone forever. Now when we occasionally encounter aliased devices (we have 5,000 devices), then deleting from RME is useless because they will come back after a re-start. I think I like the old behavior much better. Thanks again for the insight.
This was not the case. The same behavior exists in LMS 2.6. When a device is deleted from RME, it is only deleted from RME. This allows other applications to continue to manage the device.
Maybe that's the way it is supposed to work, but our systems do not behave that way. I have been using LMS 2.2 and 2.6 systems for almost 2 years and both do the same thing. After I delete a device in RME, it never returns when I restart the daemons.
RME 3.5, yes. There was no DCR in that release. In RME 4.0, a device deleted from RME would still remain in DCR. It could then be re-synced from DCR after being deleted from RME.
