Infrastructure 2.2, group by subnet?
dfaught
I just starting to migrate from Prime LMS 4.2 to Prime Infrastructure 2.2.  I have several user-defined groups based on subnet ranges in LMS, but I don't see how to do this in Infrastructure.  Any clues?
Thanks for any help,
Dave
Nikolas2008
Hello dfaught,
For accomplish what you want on the PRIME you have to create a dynamic user defined group and set the parameters of the group to search for the managment address (or subnet) of the devices that you want to be on that group.
Like this:
Hope this can help you
Best regards
Thank you for your reply.  I guess that will work, but it's a poor substitute for the range capability in LMS or actual subnets.
