09-03-2004 11:23 AM
I just installed CiscoView Device Mgr 1.0 on a new Cat 6509 switch with a single Sup 2 running Native 12.1(22)E2 IOS. I followed the installation instructions copying the tar files and extracting them to the bootflash:. I extracted the CVDM file first, then the CiscoView file second. I enabled http authentication local, http path bootflash: , and verified available VTY lines.
The problem is that when I try to launch CVDM by using http://10.x.x.x/flash/cv/applet.html, I get the splash CVDM splash screen followed by a login prompt. I enter my user name and password. It accepts this, and then I am prompted by the Java Login. It accepts this login and starts loading diceloader.
I can get no further than this. I either get a frozen screen or my Internet Explorer 6.0 window closes.
This has occurred with 3 different PCs I have used to launch CVDM.
Anyone had this similar problem.
Thanks, Robby
09-14-2004 10:24 AM
Did you try using any other Browser? Try using any latest Netscape browser. It might work.
12-22-2004 12:41 PM
Hi Robby
Please email us the device config and the details of our environment i.e. Platform used, Browser Used, Pluggin Version Used, Versions of Pluggins, Version of Browsers and what operating system was used.
-Abhijit
