Installed HWIC card does not show on router 2911 via CiscoView
mohdnazmi
I have CiscoWorks LMS v3.2 with CiscoView patch level 6.1.8. I have updated to the latest package, however, I could not view the installed HWIC on router 2911 device. What seems to be a problem?
Nael Mohammad
Level 5
Level 5
Can you post a screenshot and the show ver from the 2911? I do see the 2911 is supported but no mention of the HWIC.
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.2/device_support/table/lms32sdt.html
Take a look at the CiscoView screen capture where it does no show
any interface card installed. Also I attached the show ver of the 2911.
