Installing CA Certificates
sirbaughmf
Due to security settings in our environment, we are no longer able to support self-signed certs.  I am currently migrating to LMS 3.2 and before I can do that I need to install new certs.  I have a 3 server setup with a Master and two slaves.  I need to know what is the process for installing these new certs? to the Master? and to the slaves?  what do I need to do to get them talking?
thanks, marcie
Michel Hegeraat
Level 7
Level 7
In the directory CSCOpx\MDC\Apache there is a script SSLUtil.pl to import the certificates.
You need aBase64-Encoded X.509 Certificate.
You should read yourself in on Single sign on and DCR master-slave.
It is pretty well explained in the help.
Cheers,
Michel
