Integration New Cisco solution
Alessandro@ITConsulting
Frequent Visitor
Frequent Visitor
Dear all,
I have taken over a network configuration from a customer with mixed devices of different brands (from router, firewall switch and access point) there is no product of the same brand.
I bought a meraki mx as router/firewall with advanced (protection) licenses and catalyst 1300 switches series for the network distrib. I will have to configure as new one, vlans for all devices and services.
Management, servers, printers, wifi (mobile dev + corp laptops and guest) and for sure, I will have to configure a "temp" vlan for the actual network that is working (all on a single subnet).
Advice on how to configure the new network (segregate)?
correct to create a vlan for the network that is working?
Second step, I will have to integrate a new server, and then move the services and all PCs to the new vlans and power off legacy network infrastructure.
For the switch part, I also purchased the CBD license (I will configure the network first and then adopt the switches).
I will also appreciate links to manuals or how-to's of various kinds to support configurations of MX and CBD/Switches.
thank you in advance.
BR
Alessandro.
0 Replies 0
