06-16-2010 02:16 AM
We are seeing input errors on all the interfaces that connect to our F5's.
We have checked the duplex (hard set to 100 full both ends, swapped the cable and switch interface but not changed the F5 as all the interfaces have the same issue on different F5's and Cisco switches.
The switch is WS-C3750-24TS code 12.2(25r)SEC
#sh int fa1/0/7 controller
FastEthernet1/0/7 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is
Description: F5
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100BaseTX
input flow-control is off, output flow-control is unsupported
Last input never, output 00:00:00, output hang never
Last clearing of "show interface" counters 10w5d
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 2000 bits/sec, 2 packets/sec
5 minute output rate 3000 bits/sec, 2 packets/sec
26162416 packets input, 2535286219 bytes, 0 no buffer
Received 26891 broadcasts (0 multicast)
0 runts, 21 giants, 0 throttles
512374 input errors, 257369 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
83195901 packets output, 1867380031 bytes, 0 underruns
Transmit FastEthernet1/0/7 Receive
1871501261 Bytes 2536725439 Bytes
60868339 Unicast frames 26138764 Unicast frames
3617974 Multicast frames 0 Multicast frames
18731564 Broadcast frames 26904 Broadcast frames
0 Too old frames 2179100855 Unicast bytes
0 Deferred frames 0 Multicast bytes
0 MTU exceeded frames 1721856 Broadcast bytes
0 1 collision frames 255003 Alignment errors
0 2 collision frames 257388 FCS errors
0 3 collision frames 21 Oversize frames
0 4 collision frames 0 Undersize frames
0 5 collision frames 41239 Collision fragments
0 6 collision frames
0 7 collision frames 412735 Minimum size frames
0 8 collision frames 6098676 65 to 127 byte frames
0 9 collision frames 10296716 128 to 255 byte frames
0 10 collision frames 748567 256 to 511 byte frames
0 11 collision frames 503169 512 to 1023 byte frames
0 12 collision frames 8618196 1024 to 1518 byte frames
0 13 collision frames 0 Overrun frames
0 14 collision frames 0 Pause frames
0 15 collision frames
0 Excessive collisions 0 Symbol error frames
0 Late collisions 21 Invalid frames, too large
0 VLAN discard frames 0 Valid frames, too large
0 Excess defer frames 41239 Invalid frames, too small
22585962 64 byte frames 0 Valid frames, too small
14550725 127 byte frames
Has anyone seen this issue before?
06-16-2010 08:25 AM
Bad patch panel?
06-17-2010 12:39 AM
They are at different locations so it cannot be patch panel/cabling.
