05-06-2013 09:26 AM
I have two outside interfaces - I need all SMTP traffic to be on one and the other used for all other traffic. What is the best way to do this?
Solved! Go to Solution.
05-06-2013 11:17 AM
If it's a router, the typical method used for such a requirement would be policy-based routing.
In your case the access-list match would be for traffic from your mail server(s) on port 25 (smtp).
05-06-2013 11:17 AM
05-06-2013 12:03 PM
Thanks for the config. link
