Internetwork Performance Monitor 4.0.1
lambay2000
Level 2
Level 2
Facing issues with Internetwork performance monitor,
Trying to measure network performance for ICMP jitter, after specifying all the steps properly as per user guide,Job is getting completed sucessfully but when i try to generate a graph it says me No data found, Attaching a error.
Am trying to get the performance between 2 cisco switches.
18 Replies 18
Shutdown Daemon Manager, then remove all files and directories under NMSROOT/MDC/tomcat/work/Standalone/localhost. Then restart Daemon Manager, and see if the graph settings dialog has changed.
Hi clarke,
Am getting the same error for the same collector shown in the attachment of previous mail after guiding the steps from above mail.
The collectors what i created today am able to get the graph for that after specifying proper time but not for the collector shown in the attachment in my last mail.
Thanks for ur support.
There may have been a problem with that collector. Try creating a new limited life collector, and see if the new one works.
Hi clarke,
The new collectors are fine but for the one which i have attached may i think there may be some problem in that,
thanks for ur support.
