INVALID INPUT DETECTED USING CONFIG TERMINAL COMMAND
crismartc44
Hello, someone can help me .
to set the ip of the router i need to go in configure terminal
i already try
conf t
config terminal
configterminal
configure terminal
its not working, it say invalid input
my ap model is AIR-AP1832I-A-K9
7 Replies 7
crismartc44
im just following this instruction
How to configure standalone Cisco access point from GUI and configure WPA2 authentication - YouTube
but i cant proceed in configure terminal because i got an error
Ben Walters
Level 4
Level 4
It looks like the AP might be running the lightweight software.
If you run the command show version | include image
The image name of the standalone version contains k9w7 - this is the one you want.
The lightweight version contains k9w8. - If this is the case you would need to download the standalone software and install it on the AP.
If you are running the standalone version then it might be the AP type setting. Can you run the command ap-type mobility-express? If that is successful the AP should reboot into standalone mode.
thanks for the reply, i'll try to download the standalone software.
i can access mobility express but i can't access the URL ip, i set it as static
Should I use mobility express?
i cant access the mobility express in the URL using this mobilityexpress.cisco or the IP i set for AP.
I'm new in AP, please help me. thanks
what is the next step sir? i want to access the ap in URL
Do you see the AP broadcasting a wireless network called CiscoAirProvision
The default password is password
If you see that network and are able to connect you should be redirected to mobilityexpress.cisco, if you aren't redirected, you can also go there manually or use the IP address 192.168.1.1
This is all from the config guide here:https://www.cisco.com/c/en/us/td/docs/wireless/access_point/mob_exp/83/user_guide/b_ME_User_Guide_83/b_ME_User_Guide_83_chapter_01000.html
