invrep0027 dbconnection resource release failed
Anas Hijjawi
We are getting the below error when generating a report for Invetory
Can any one assist please
Anas
*--* Please rate the useful post,its free *--*
Thanks, Anas *--* Please rate the useful post,its free ;) *--*
11 Replies 11
AFROJ AHMAD
Hi Anas,
seems to be this BUG , Contact the TAC  team, they will give you the Patch.
https://tools.cisco.com/bugsearch/bug/CSCuf79864/?reffering_site=dumpcr
Custom Inv Report is not showing  module info when slotNum is null
Thanks-
Afroz
[Do rate the useful post]
****Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
I believe that this bug is not the same what we are getting, it is related to module information only
Anas
are you running Custom reports ?
Thanks-
Afroz
Yes
Anas
then ,it could be the BUG.
condition:
When the slotNum  is having null value or negative value
you can share the INVREPORTS.log  ( enable the debug for invreport module ,re-run the job)
Thanks-
Afroz
Anas Hijjawi
[ Sun Mar 02  13:23:53 GST 2014 ],INFO ,[TP-Processor8],com.cisco.nm.rmeng.inventory.reports.ui.action.InventoryReportsAction,perform,431,InventoryReportsAction Getting request params : ReportNAme: Invetory_CollectionApp Name : null
[ Sun Mar 02  13:23:53 GST 2014 ],INFO ,[TP-Processor8],com.cisco.nm.rmeng.inventory.reports.ui.action.InventoryReportsAction,perform,440,Action of Filter is null
[ Sun Mar 02  13:23:53 GST 2014 ],INFO ,[TP-Processor8],com.cisco.nm.rmeng.inventory.reports.ui.action.InventoryReportsAction,perform,977,Generate report Request from UI
[ Sun Mar 02  13:23:53 GST 2014 ],INFO ,[TP-Processor8],com.cisco.nm.rmeng.inventory.reports.ui.action.InventoryReportsAction,perform,1832,progresssiteMap
[ Sun Mar 02  13:23:54 GST 2014 ],INFO ,[TP-Processor8],com.cisco.nm.rmeng.inventory.reports.ui.action.InventoryReportsAction,perform,431,InventoryReportsAction Getting request params : ReportNAme: nullApp Name : null
[ Sun Mar 02  13:23:54 GST 2014 ],INFO ,[TP-Processor8],com.cisco.nm.rmeng.inventory.reports.ui.action.InventoryReportsAction,perform,440,Action of Filter is fromProgress
[ Sun Mar 02  13:23:54 GST 2014 ],INFO ,[TP-Processor8],com.cisco.nm.rmeng.inventory.reports.ui.action.InventoryReportsAction,perform,977,Generate report Request from UI
[ Sun Mar 02  13:23:54 GST 2014 ],INFO ,[TP-Processor8],com.cisco.nm.rmeng.inventory.reports.ui.action.InventoryReportsAction,perform,1863,selected immediate report generation
[ Sun Mar 02  13:23:54 GST 2014 ],INFO ,[TP-Processor8],com.cisco.nm.rmeng.inventory.reports.ui.action.InventoryReportsAction,perform,1864,The value of casIds is null
DEBUG,2014-03-02 13:23:54,646,Datagenerator class name is class com.cisco.nm.rmeng.inventory.reports.datagenerators.CustomRDG
DEBUG,2014-03-02 13:23:54,647,Datagenerator class instance is  com.cisco.nm.rmeng.inventory.reports.datagenerators.CustomRDG@4fa1bc2a
[ Sun Mar 02  13:23:54 GST 2014 ],INFO ,[TP-Processor8],com.cisco.nm.rmeng.inventory.reports.datagenerators.CustomRDG,getData,94,Entered into CustomRDG class
[ Sun Mar 02  13:23:54 GST 2014 ],INFO ,[TP-Processor8],com.cisco.nm.rmeng.util.DCRWrapperAPIs,getDisplayNamesForDevs,876,Data is taken from DCR Memory Cache in getDisplayNamesForDevs
[ Sun Mar 02  13:23:54 GST 2014 ],INFO ,[TP-Processor8],com.cisco.nm.rmeng.inventory.reports.datagenerators.CustomRDG,getData,124,Devices have no data []
[ Sun Mar 02  13:23:54 GST 2014 ],INFO ,[TP-Processor8],com.cisco.nm.rmeng.inventory.reports.custom.PersistTemplate,getTemplateDetails,911,getTemplateDetails is called to get template details
[ Sun Mar 02  13:23:54 GST 2014 ],INFO ,[TP-Processor8],com.cisco.nm.rmeng.inventory.reports.custom.PersistTemplate,getTemplateDetails,999,Template id 3
[ Sun Mar 02  13:23:54 GST 2014 ],INFO ,[TP-Processor8],com.cisco.nm.rmeng.inventory.reports.custom.PersistTemplate,getTemplateDetails,1053,inside column details
[ Sun Mar 02  13:23:54 GST 2014 ],ERROR,[TP-Processor8],com.cisco.nm.rmeng.inventory.reports.datagenerators.CustomRDG,getData,169,Exception thrown in getData methodjava.lang.NullPointerException
    at com.cisco.nm.rmeng.inventory.reports.datagenerators.CustomRDG.getData(CustomRDG.java:148)
    at com.cisco.nm.rmeng.inventory.reports.datagenerators.DataGenRequestHandler.getData(DataGenRequestHandler.java:46)
    at com.cisco.nm.rmeng.inventory.reports.ui.action.InventoryReportsAction.perform(InventoryReportsAction.java:2356)
    at org.apache.struts.action.ActionServlet.processActionPerform(ActionServlet.java:1786)
    at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1585)
    at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:509)
    at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
    at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
    at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
    at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
    at org.ajaxanywhere.AAFilter.doFilter(AAFilter.java:46)
    at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
    at com.cisco.nm.cmf.util.AccessLogFilter.doFilter(AccessLogFilter.java:128)
    at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
    at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
    at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
    at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
    at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
    at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:291)
    at org.apache.jk.server.JkCoyoteHandler.invoke(JkCoyoteHandler.java:190)
    at org.apache.jk.common.HandlerRequest.invoke(HandlerRequest.java:291)
    at org.apache.jk.common.ChannelSocket.invoke(ChannelSocket.java:776)
    at org.apache.jk.common.ChannelSocket.processConnection(ChannelSocket.java:705)
    at org.apache.jk.common.ChannelSocket$SocketConnection.runIt(ChannelSocket.java:898)
    at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:690)
    at java.lang.Thread.run(Thread.java:662)
[ Sun Mar 02  13:23:54 GST 2014 ],ERROR,[TP-Processor8],com.cisco.nm.rmeng.inventory.reports.datagenerators.CustomRDG,getData,175,Exception thrown in getData method while connection closingcom.cisco.nm.rmeng.inventory.reports.util.IRException: InventoryReports.DBConnectionFailed
    at com.cisco.nm.rmeng.inventory.reports.datagenerators.CustomRDG.getData(CustomRDG.java:171)
DEBUG,2014-03-02 13:23:54,684,InventoryReports.DBConnCloseFailed
com.cisco.nm.rmeng.inventory.reports.util.IRException: InventoryReports.DBConnCloseFailed
    at com.cisco.nm.rmeng.inventory.reports.datagenerators.CustomRDG.getData(CustomRDG.java:176)
[ Sun Mar 02  13:23:54 GST 2014 ],ERROR,[TP-Processor8],com.cisco.nm.rmeng.inventory.reports.ui.action.InventoryReportsAction,perform,2368,Exception thrown from getData call in InventoryReportsActioncom.cisco.nm.rmeng.inventory.reports.util.IRException: InventoryReports.DBConnCloseFailed
Anas
Anas,
Thanks for sharing the logs:
    at
CustomRDG.class file is corrupt. the patch will give you a new class file that need to be replaced to get the
reports working
Thanks-
Afroz
which patch, can you share it with me
Anas
Please conatct TAC to get the patch.
Patch include the .class file.
Thanks-
Afroz
Anas Hijjawi
If I get a copy of this file, I can replace it?
Anas
Hi Anas,
yes ,if that file contain the fix.  Just replace it with the existing one.
Note: keep the backup of original file. Also check the premission of the new file after the replacement.
Thanks-
Afroz
