Hi all,
I am running multiple cisco 3550 24 -SMI switches in my network . Now as per cisco this is the latest IOS image(c3550-ipservicesk9-mz.122-44.SE6) for this product and Security guy did Vulnerability assessment on the switches and found that this IOS is vulnerable and should be upgraded to above 12.2 (44). I found another IOS above 12.2(44) which is 12.2 (55) but it is for 3550 24 DC SMI .
my question is, if I upgrade 12.2 (55) IOS to 3550 24 SMI switch, will it work or not ? I have seen in access point if ios is in same series then it works for multiple models, I am not sure if it works for switches as well.
I would appreciate if some helps me. thanks in advance.
